Long story short, I’m caching hundreds of images before showing users the home screen. This way I’m not calling the records with each click and there’s no delay… The app loads every record, every time on a highspeed connection but on slow WIFI, I’m getting errors or time-outs which causes the content not to fully load. Do I need to add 1 second delays after every 5 records because of the limit per-base? Or is there something else that could cause this? Here’s a screen recording of the app loading successfully. You can see the “image loaded” print strings in white, then I’m logging what has completed in green. Maybe it will help illustrate something I’m doing wrong. Thanks!
