"Fields" could not be converted to a string
Topic Labels: Automations
1272 3
Liran_hamburg
Hi, im trying to create an automation that will move data from a field with a formula to another tab whenever a trigger is activated, but for some reason, i get this error - “Fields” could not be converted to a string.
can somebody help solve the mystery?
Thanks,
Liran
Databaser
12 - Earth
12 - Earth
Hi @Liran_hamburg
What format type does your formula field has?
3 Replies 3
Databaser
12 - Earth
12 - Earth
Hi @Liran_hamburg
Liran_hamburg
@Databaser Hello!
Problem solved - thanks for the help
datasofi
I am facing the same issue. Some detail would help. Even years later. Thanks
