Filter custom block content by Airtable View
958 1
Sumit_Kapoor
Is there a way to create a Dropdown Menu inside a custom Block to filter by own configured Airtable Views?
I’am not quite sure if this is what would work for my case.
Is there any Example Demo/Code for that?
Rick_Waldron
Can I assume that you’re programming this custom Block? If so, then I believe what you’re looking for is ViewPicker:
import React, { useState } from "react";
import { ViewPicker, useBase } from "@airtable/blocks/ui";
const ViewPickerExample = () => {
  const [view, setView] = useState(null);
  const base = useBase();
  const table = base.getTableByNameIfExists("Tasks");
  // If table is null or undefined, the ViewPicker will not render.
  return (
    <ViewPicker
      table={table}
      view={view}
      onChange={newView => setView(newView)}
      width="320px"
You can sync that up to globalConfig, with ViewPickerSynced:
import React from "react";
import { useBase, ViewPickerSynced } from "@airtable/blocks/ui";
const ViewPickerSyncedExample = () => {
  // If table is null or undefined, the ViewPickerSynced will not render.
  return (
    <ViewPickerSynced table={table} globalConfigKey="viewId" width="320px" />
Rick_Waldron
  return (
    <ViewPicker
      table={table}
      view={view}
      width="320px"
  return (
