Help with an IF AND statement, possible a rollup?
827 2
czacza2007
Hello, I’m trying to do a formula that calculates commision due. I have the commission field, and I also have a ‘commision paid’ checkbox field.
Basically I want the commission owing field to calculate the commission if the paid field isn’t ticked yes.
Help please!
Mohamed_Swella1
13 - Mars
13 - Mars
Hi @czacza2007,
You can use this article to create your formula
Basically, it will be something like IF({Commission Paid} = 0, Commission, 0)
BR,
Mo
Mohamed_Swella1
13 - Mars
13 - Mars
Hi @czacza2007,
BR,
Mo
Thanks Mo, that fixed it!
