Hey guys I need your help
2140 5
Niza_Siwale
Does the custom block API allow us to call POST/GET requests to external services such as one’s own AWS EC2? It seems that I can only call Wikipedia and other services fail
Ashwin_P
The URL has to start with https
5 Replies 5
Ben_Orozco
7 - App Architect
7 - App Architect
It’s possible, it might be other kind of issue
Have you managed to make a POST request to anything other than Wikipedia before?
As even the calls to openweather fail. I’m trying to connect to my AWS EC2 instance
const weatherURL =
http://api.openweathermap.org/data/2.5/forecast?zip=11102&units=imperial&APPID=key
fetch(weatherURL)
.then(res => res.json())
.then(data => console.log(“Data List Loaded”, data.list))
Shaun_Van_Weeld
I’ve indeed made other calls (to my own BE service) as part of this custom blocks beta. For better and for worse, it’s likely a coding error on your side.
Here’s part of the code I have in my current block:
const payload = {
    config: config._kvStore,
    message,
  request.post(
      headers: { 'content-type': 'application/json' },
      url: `${ENV.DEV.BASE_API}do_something`,
      body: JSON.stringify(payload)
    function (error, response, body) {
      if (error) {
        console.error(error);
      } else {
        console.log(body);
Ashwin_P
