How to delete or move first column?
Topic Labels: Base design
1706 1
Henrik_Jorbrant
Hi, I got several columns in a base. Now I want to delete or move the first column but that option is not available in first column for me and I’m owner. Look forward for help.
M_k
11 - Venus
11 - Venus
Hi @Henrik_Jorbrant
The first column is the Primary column and, unfortunately, that first column cannot be moved or deleted. It’s a locked column.
Hope this helps, eventhough it might not be what you were looking for.
Mary Kay
