IF formula not working to pull data from two columns
1433 2
Valerie_Martin
This formula is not working to pull data from the two formula columns (Days Actually Out and Backdata days out) I want. It seems so simple. If the DATE OUT is before or is today, pull this number. If the date is AFTER today, pull another.
IF({Date Out} <= TODAY(), {Days Actually Out}, IF({Date Out} > TODAY(), {Backdata days out}))
It currently only pulls the ‘Backdata days out’ data for this column. . . Can anyone tell me if this is a no-no in AirTable or if I’m doing something wrong?
PC1
Not sure if this is your issue but here is a link to a similar problem I had. It was suggested (and worked) to add AND.
AlliAlosa
10 - Mercury
10 - Mercury
Is {Date Out} a date field? If not, that could be the source of your problems.
I actually didn’t realize that Airtable supports logical operators in comparing dates, but it appears they do. I tested your formula and it worked for me (but if {Date Out} is not a date field, it will produce wonky results).
I would say it’s probably better practice, though, to change your logical operators to date time functions like IS_BEFORE(), IS_SAME(), and IS_AFTER().
Try the following:
IF({Date Out}, IF(OR(IS_SAME({Date Out}, TODAY()), IS_BEFORE({Date Out}, TODAY())), {Days Actually Out}, {Backdata days out}))
