Need Help Creating a Purchase Order
2618 2
Support_AspenTy
Hi Guys,
I need help on whats the best way to create a purchase order. Right now I’m currently creating a template with paper designer and im linking the items with the correct table. Is there a template available which I can look at to use some of the features. So far im at this but i need to add quantity and total price per item and was confused on how to do it without altering anything else. Sort of like an automated thing where I can just enter a static text and it adds the prices.
Screen Shot 2019-12-23 at 1.37.29 PM
Help would be much apperciated.
Thank you
AlliAlosa
10 - Mercury
10 - Mercury
Hi there - looks like you might need a junction table. Take a look at this reply I just wrote regarding a similar situation: Adding weight to produce purchased
This example base might help you as well; it demonstrates how to set up invoices and line items. There is also very basic Invoice (which could easily be turned into a Purchase Order) in the Page Designer Block.
Hope this helps!
Patrick_Olson
Hi there I am some what new to air tube and I am hoping you might help me to learn how to get paid from submissions being sent in. What I sent in was somewhat of a love story of my life and how I am wanting to change. My name is Patrick T. Olson.
