Need Help figuring out the 3rd Number
724 3
Abraham_Bochner
8 - Airtable Astronomer
I have only 2 numbers
  1. 15%
  2. 161.80
I have to get after the deal is done $161.80 and the the other guy have to get 15% of the deal.
So the total deal will be $190.35 - (161.8 is a 15% decrease of 190.35.)
How can I get to this number ($190.35) in Airtable, when I have only the 2 other numbers (1. 15% 2. 161.80)
In Excel I will make this as follows =161.8 / (1-15%) but I can not make this work in Airtable
Screenshot_175
Thanks in Advance
Jason
Airtable Employee
Airtable Employee
Hi @Abraham_Bochner,
You’ll just need to change 15% to .15, making the formula {Total Cost} / (1-.15). Then, make sure to format your field as currency. Hope that helps!
Screen_Shot_2020-06-18_at_5_23_26_PM
3 Replies 3
Jason
Airtable Employee
Airtable Employee
Abraham_Bochner
Thank you very much , Quick Help
Happy to help Abraham!
