Need to save custom base as a template for personal use (i.e., NOT as link to share via Universe)
Topic Labels: Base design
1256 2
Cindy_Chadwick
I need to create and save my own custom base template for strictly personal use (i.e., not for sharing.) I need to create dozens of bases with the same exact schema (field structure). I can only find information on sharing bases, not on saving a custom base as a template for your own personal, repeat use.
18 - Pluto
18 - Pluto
Just choose “duplicate base” from the base icon dropdown menu in the home screen… or from the 3 little dots that show up within the base when you click on the base name.
(And be sure to move it to a workspace that you haven’t shared, or remove any collaborators that are already attached to it.)
18 - Pluto
18 - Pluto
Thanks, ScottWorld. I just figured that out and came back to delete the question, lol. Complete newbie…just started about an hour ago. Hadn’t seen the ‘duplicate base’ option. At least this answer is now out there for other newbies with the same question. :grinning:
