Org Chart Block Settings
Topic Labels: Extensions
662 0
Mamizo_Ravaloso
Hi AirTable Community,
I am creating an org chart for my company right now. The company employs 250+ people, and many of the lowest stage people of the organization share the same manager. As a result, it takes a lot of space horizontally to display all of them, which makes the visualization less comfortable.
Does anyone know how to
1 - Display less fields than the upper stages (keeping only the name of the employee for example).
2 - Group all those names inside one unique box, to gain space.
Thanks for your help,
Mamizo
0 Replies 0
