Picture thumbnails not displaying in slack
2563 0
Dorian_Tohou
Hello there :wave:
I have a slight issue, where I’m using slack bot to populate a message coming from a filled form in Airtable. When receiving that form in Airtable, I’m using an automation to populate that message directly in slack.
The problem : The issue is coming from attached files (pictures essentially) in the form. I cannot load the images thumbnail in the slack message. Did some of you face the same issue ?
Thanks a lot for your help :pray:
screen-capture
0 Replies 0
