I am getting the following error when trying to run a custom app (have tried 4 different apps and same result with each one). Any help would be greatly appreciated. Thanks
ReferenceError: _airtableReact is not defined
at Object. (https://static.airtable.com/js/by_sha/3f43c1b0/block_frame.js:1:61606)
at r (https://static.airtable.com/js/by_sha/3f43c1b0/block_frame.js:1:361)
at Object. (https://static.airtable.com/js/by_sha/3f43c1b0/block_frame.js:1:642245)
at Object. (https://static.airtable.com/js/by_sha/3f43c1b0/block_frame.js:1:704425)
at Module. (https://static.airtable.com/js/by_sha/3f43c1b0/block_frame.js:1:2445491)
at async Promise.all (index 1)
