Revision history and comments sort order in record view
1068 3
Ron_Nedd
Currently, the record level revision history shows with the oldest on top. That view also puts newer comments at the end/bottom. If I want to see something recent I have to scroll all the way to the bottom. Is there any way to reverse that so that comments and revision history shows with the most recent at the top?
3 Replies 3
Kate_Wright1
Agreed, having the ability to sort comments newest to oldest would be beneficial, especially if sharing comments in Interfaces.
Ben_Hanni
Just ran into this as well.  Wanted to add comments to Interfaces, but use case is problematic with current oldest to newest.
Even the community forum here gives the option to sort either New>Old or Old>New.
kiwifidget
Nearly 3 years since this thread raised this issue, and still no option to sort newest on top. I'd like that feature too please.
