Script to combine Projects and Task
791 0
Anders_Skjodt
Hallo
I need some more brain-power…
I have a table with Projects and a table with Task.
I will like to combine all Projects and Task in another table ProjectTask
I have try with a automation, but I can’t group all the ‘Create record’ in one action. That means that I need to create a ‘Create record’ for each task, that will fail when I add a new task to the table.
Is it possible to create one ‘Create record’ there look at all the task?
I sure is can be handle by a script – can anyone help me with a script?
0 Replies 0
