Using FormData in scripts
1542 2
Tom_Beckenham1
I’m getting an error when I try to use create a Javascript FormData object in preparation for posting to an API. I would have thought FormData would have been well supported.
console.log(`Hello, ${base.name}!`);
const endPoint = new URL('https://myserver.com/jsonAPI/');
const formData = new FormData();
formData.append("user", 'tom');
const response = await fetch(endPoint.toString(), {
    method: "POST",
    body: formData,
console.log(response)
Getting an error saying that FormData is not defined
Thomas_Brady
They mention in their docs that the FormData API is not available in Airtable Scripting: Airtable Scripting
Titouan_Parand
To use formData you can build the object yourself using:
let data = {
    key1: 'value1',
    key2: 'value2'
// Encoder les paramètres en format x-www-form-urlencoded
let formData = Object.keys(data).map(key => encodeURIComponent(key) + '=' + encodeURIComponent(data[key])).join('&');
await fetch('URL_DE_VOTRE_API', {
    method: 'POST',
    headers: {
        'Content-Type': 'application/x-www-form-urlencoded',
    body: formData
