Using prevous or above record data in formula
1403 1
Ashley_Mills
Hey all!
I am trying to use Airtable as an excel spreadsheet to track my budget. Is there a way to create a formula that use the previous records ‘current balance’ amount for the formula so it will update each record (transaction). I really appreciate any help you can offer!
You’d need to either link your records together or use some form of Automation, script, or manual process to copy a value from the first record to the second.
Similar posts from today and yesterday:
