When embedding base on website, can you change view layout of apps and tables e.g. on top of each other not side by side?
Topic Labels: Base design
484 0
Alex_Manning
Hello, this is with regards to embedding a base on my Webflow website. I’m wondering if it is possible to display my airtable with a map vertically (on top of each other) rather than horizontally (side by side)? This way the map is in full view and so is the table, rather than squeezed into the width of the screen.
Such as in the drawing here thumbnail
Thanks in advance.
0 Replies 0
