Jan 07, 2023 07:34 PM
Hi AT Community,
I'm creating an automation email within Airtable that uses percentage field data from my table. I have set the precision to one decimal place (1.0) in the field column.
However, when testing the automation, the preview shows that the token data percentage with 10 decimals (1.000000000), which looks ridiculous.
Anyone know why this is happening?
I know the workaround is a single-line entry, but I'd prefer to be able to enter the data as the percentage number, as that's how the information comes to us.
Appreciate your help!
Solved! Go to Solution.
Jan 08, 2023 10:46 PM
The "decimal precision" you set on a column , determines only the formatting you see in Airtable. The underlying number remains the actual complete number up to the length that the database allows. This is in case you want to change the decimal precision.
Looks like the second screenshot is a body of an email or similar? Best would be to format the data at destination, e.g. if you are using an external tool. In case this is e.g. email inside automations - I don't think there are any formulas to format it there.
Solution could be to have a formula field, which uses ROUND(value, precision) . If you use that field in Automations, it will output the number as text visible as result of the formula - meaning with decimals you need.
Let me know if that helps?
Jan 08, 2023 10:48 PM
Hm, perhaps you could try adding a formula field with a `ROUND()` or other equivalent and using that for your automation instead?
Jan 09, 2023 02:36 PM
Great, thanks Greg. That's the solution and good to know why it was happening. To extend on it, I'll hide the formula field to keep the base a little cleaner.
That's it. Thanks Adam. Appreciate it.
