Using Automation to create a new record and auto-populate certain data
  • November 7, 2023
  • 525 views
I am new here and am trying to find a way to create a new record (and auto-populate some data into this new record) when the user pushes a button on a different table.
Example:
I have table A and table B. I want to find a way whereby if the '2024 Definate Grow out' box is checked on a given record in table A, a new record is automatically inserted into table B, which copies over some of the data from the relevant record in table A into this new record in table B.
I have managed to create an automation which inserts a new record in Table B every time I push the button on a record in Table A, but do not know how to copy across the data into the new record on Table B or if this is even possible.
Thank you!
Z
Databaser
Forum|alt.badge.img+25
  • November 7, 2023
In your "create record" step, you should be able to add fields ("+ Choose fields") from your table B and match them with values from fields in your table A.
  • November 7, 2023
Thanks Databaser,
I can see that I can add the fields to table B as part of the 'create record' step, but I am wondering if I can pull the relevant values across from table A into my new record in table B. Do you know if this can be done? I effectively want to create a duplicate record in table B, for each of the table A records that I check the box on.
Thanks so much for your help!
Best wishes,
Z
Databaser
  • November 8, 2023
Thanks Databaser,
Best wishes,
Z
The "field" of table A that you set for table B, like "Name" in the rectangle with the blue "+", will actually transfer the data inside that field, not the field itself. You could create a record in table B and link it to the original one in table A and use lookup and/or rollup fields.
  • June 17, 2025
I just set the automation trigger to “when record matches conditions,” then used the “create record” action and pulled in data from the trigger step using dynamic fields—it worked smoothly.
  • June 20, 2025
I had one table for parent plants and another for clones, and wanted to auto-fill clone info when I clicked a button. Ended up using conditional logic in the automation to map fields over—took me a bit to figure it out but it worked! Felt kinda like learning how influencers monetize with Stan Store—once you understand how to connect the pieces, it all clicks and runs smooth.
