- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
‎Dec 13, 2023 05:53 AM
I'm using a no-code tool and I want to have a multi-like with Airtable.
On the no-code side, we've set up GET, POST and PATCH to make the like work, but the problem is that it's not attached to a single user. In other words, let's say user A posts a like that goes to the favorites page, user B and C log in and see A's likes and vice versa. After speaking with the no-code platform, they tell us that the solution must be found by Airtable because it's the backend -> I'll share with you what XANO is doing. The idea is the same principle, but with Airtable if possible: https://www.xano.com/snippet/qCmG9KcL/J I'm using a no-code tool and I want to have a multi-like with Airtable.
On the no-code side, we've set up GET, POST and PATCH to make the like work, but the problem is that it's not attached to a single user. In other words, let's say user A posts a like that goes to the favorites page, user B and C log in and see A's likes and vice versa. After speaking with the No-code platform, they tell us that the solution must be found by Airtable because it's the backend -> I'd like to share with you what XANO is doing. The idea is the same, but with Airtable if possible: https://www.xano.com/snippet/qCmG9KcL/
