Need help removing Error from a formula
666 1
wlauro1
I'm terrible at the formula stuff, but basically I have a Publish Date in my Airtable view for when a piece of content should be published. I want to add the Day of Week as well so we can clear see which post is which day, as well as the actual date (as some gets scheduled a bit further in advance)
The formula I'm using to display the day is:  DATETIME_FORMAT({Publish Date},'dddd')
All I need to do is display nothing if there is no publish date set
Databaser
12 - Earth
12 - Earth
This should work for that:
IF({Publish Date}, DATETIME_FORMAT({Publish Date},'dddd'))
Databaser
12 - Earth
12 - Earth
