When criteria is not met, leave field blank (help)
117 1
plyske
7 - App Architect
7 - App Architect
Hello everyone!
I have this formula:
IF(AND(DATETIME_FORMAT({Trækdato (FarPay)}, "D")<10, DATETIME_FORMAT({Dato for udløb}, "D")<10),
IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))=3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),1, "weeks"),
IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))<3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),3-WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD")),"days"),
IF(WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"))>3, DATEADD(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD"),10-WEEKDAY(DATETIME_PARSE(DATETIME_FORMAT({Dato for udløb}, "YYYY-MM-10"),"YYYY-MM-DD")),"days")))))
Currently when the field 'Trækdato (FarPay)' is empty, it will give an '#ERROR!'. I want it to just leave the field blank. Is that possible?
joshsorenson
Try this, basically, you need to tell it if the field is blank to return the empty value.
IF({Trækdato (FarPay)}=BLANK(), BLANK(),
