Column Index concept, to be able to locate columns
Topic Labels: Views
169 0
Karl_at_Easy_La
I'm not sure if this is possible, but I'm going to try my luck. I have a table with a lot of columns, and lots of records.  Sometimes, I need to find a particular set of records.  Considering I have say 100 columns,  I then need to locate the column. I use the "Find" feature to search for the column name, which locates it.  However, if I then have to move around the dataset to locate certain rows, I might need to move horizontally within the view, to locate certain information. This makes me end up losing the horizontal position of where that column is. Considering that there is no concept of a column index, I cannot say "Column Name" is Column Index 50 in this view, and then I can easily scroll to it.  I need to remember the scrollbar position, which is very vague.
I'd appreciate if you have any advice on this matter. I've recorded this video to explain better the issue I face: https://drive.google.com/file/d/18OXTCcNaJG9AnsGCWlEB9-PAeLn2mrH7/view
0 Replies 0
