Synced airtable: add record without two-way syncing
381 1
Timo12
I have 1 large airtable with jobs that I sync to airtable bases of clients in the same workspace.
Now they should not be able to edit these jobs, so that's perfect.
However, within that tab I want them to be able to add other jobs they might have, only for their use. How can I do this? I cannot see any way of doing this, and I don't want it to be a two-way sync, as those jobs should only visible for them. Ideally in the same tab as the other non-editable jobs. Is there a workaround?
In some other tab they can link jobs to applicants with a linked record. I want that to still be the same job tab, otherwise It would not work well (if I have them make jobs in a different job tab)...
Any workaround or creative wizardry?
Dimitris_Goudis
10 - Mercury
10 - Mercury
Hey @Timo12
You can add 2way  sync and prepare for them an interface where they can't edit records but they can create new ones through a form.
Would that work for you?
