Hi. I am using the project tracker template. I have made a number of changes to the fields while in the all projects mode. When I look at the completed projects or incomplete projects view these changes do not show
How do I get any changes to show across all views. Thanks
If you want one view’s setup to be a direct copy of another view, click the down arrow next to the view’s name, then choose “Copy another view’s configuration”. You can copy as much or as little as you want, but my guess is that you only need to copy the field visibility and field order.
