About the automation for reminder
Topic Labels: Sync
874 2
station
Is it possible to create an automation that notifies/or record update when XXX days have passed since I created a particular record?
I wish I could do this.
(e.g. record update case)
1_created record & get the “created time”
2_2week passed from “created time”
3_some status automated change A from B
I’m having a deja vu.
Granted, your use case isn’t identical but you could tweak that formula I just shared to serve as a trigger for your email automations. It’s going to work more reliably than declaring a bunch of IF conditions using the no-code interface. Or at least with a smaller delay between the conditions matching and the run triggering.
station
@Dominik_Bosnjak
thanks your kindly reply!!!
I’ll try it!
