Base Design for article records with multiple recipients
Topic Labels: Base design
692 1
Stephen_Whitwel
Dear AirTable,
I have a database question. (I use Airtable for other things and it works very well).
I send out articles from time to time, in PDF format. I am using an Excel spreadsheet to record who I send it to, when it was sent, and what article was sent. This is all so I don’t double up and send someone the same article.
I have looked at Airtable, but I can’t see a way of doing it.
This is what I need;
  • A list of recipients
  • A total number of recipients
  • A list of articles
  • A total number of articles
  • A total number of all articles sent,
  • A total number of articles sent per article
  • The dates for each article sent
All of that info I have in the spreadsheet, but there’s only one date available for each recipient per article. For example, I can’t record more than one date for the same article going to the same recipient.
Another drawback is that adding a new article to the list, means adding two new columns, setting them up etc, etc, which is a bit time consuming. I’d love to be able to have it easier to add articles.
I would like to see a ‘report’ of;
  • List of recipients and what articles they have been sent and on what date
  • List of articles and who they have been sent to and on what date
  • Chronological date list with who has received what article
  • Searchable for dates, recipients, and articles
Any ideas?
The Excel Spreadsheet works, but it is cumbersome, and time consuming to add new articles.
Thank you!
I look forward to hearing from you.
Kind regards,
Stephen Whitwell
Tauranga
New Zealand
stephen@goodwords.nz
Try the following base structure:
  • Table: Recipients
    • Fields: {Lookup of the "Article" field from the Activity table}
  • Table: Articles
    • Fields: {Lookup of the "Recipient" field from the Activity table}, {Count of linked Activity records}
  • Table: Activity
    • Fields: {Date field}, {Link to Article}, {Link to Recipient}
    • Views: Grouped by {Link to Recipient} and Sorted by {Date field}; Grouped by {Link to Article} Sorted by {Date field}
