Choosing fields for Pie Chart
Topic Labels: Extensions
1593 3
Rob_Cahill
Dear Community,
I am new to Airtable. I am making my first block. I have a table with multiple fields. I want to make a Pie Chart with just two of the fields.
I made a pie chart from the table but it includes all the fields in the table. How can I select just two of those fields?
Thank you in advance for your help.
Rob
Why don’t you post some screenshots of what you have so far, and then describe what you’d like to accomplish.
3 Replies 3
I think you mean records, not fields?
The.chart block, like most blocks, pulls in all of the records from a specific view.
So you would need to create a new view that is filtered to only show you the records that you want — and then use that view in the chart block.
Thanks ScottWorld for getting back with me. So maybe Airtable cannot do what I was thinking it could. Let’s say I have a list of counties, Field 1 is the list of the names of counties. Field 2 is the % of the population of that county that is Urban and Field 3 is the % of the population that is Rural. Is it possible to make a Pie Chart for each county for the Urban / Rural ratio?
I appreciate your help.
Rob
