Access problems when using Norton Secure VPN
  • August 30, 2020
  • 63 views
I am trying out Norton Secure VPN. I encountered two problems. Neither of these occurred with my previous VPN (NordVPN).
  1. I have a table with a single field that is “single line text.” The table is sorted on that field and “keep sorted” is selected. When I added a new entry, it was not sorted into place, but rather stayed as the final entry in the table.
  2. When I tried to input a new entry in a more complex table via a form, a blank entry was added, without all the information that I entered on the form.
Has anybody else experienced these problems, possibly with a different VPN? Thanks,
Hershel
  • October 31, 2024
If you’re still stuck, consider reaching out to support for both the VPN and the app. They might have specific tips that could resolve your issues quickly.
  • October 31, 2024
I’ve had my share of VPN troubles, too, especially when switching from a solid option like NordVPN. Once, I was using a database for tracking projects and had similar sorting issues. New entries wouldn’t stay in order, which was a headache!
For your table, it might help to double-check if there are any auto-save features that could interfere with the sorting. Sometimes, VPN settings can affect how data is processed or saved, especially with complex tables. Also, I found that using best mobile proxies improved my connection and stability while using different apps.
