Disable “Base Description” pop-up on first view
Topic Labels: Views
847 0
Tricia_Maia
How can one disable the “Base Description” pop-up on first view (that is explained here)? It’s routing viewers to the [unintended] list view when they should be going to a Gantt chart view. This issue doesn’t happen on subsequent visits.
0 Replies 0
