[Feature Request] Make "post channel" a variable in Slack automation?
Topic Labels: Automations
642 0
Erwan_Pannier
Hello !
First thing : great work on the Automations, it’s an amazing feature and I love seing the platform being improved every week !
I had a feature request :
  • the “Send an Email” action allows you to use data from the Trigger Record to specify the mail recipient
  • I’d like to be able to do the same with the “Send a Slack message” action, i.e., specify the channel with data from the Trigger Record. Right now I have to create one Automation per channel, which is cumbersome.
Best,
0 Replies 0
