Filtering by location and then creating a map
Topic Labels: Base design
2340 2
Shubha_Bala1
Hi! This may be too big of a question but I wanted to try… there’s two components to what we want.
1 - Someone is going to enter their address via a form. We then want to search one of our tables to find every office within say 10 miles of that person’s address. Is that possible?
2 - Once we hopefully have a list of offices that meet the location criteria, we’d want to show those offices on a map.
That’s certainly within the realm of possibilities for a Custom App. Are you inquiring to find a developer to build it for you? If so, I would recommend switching this to the “Development & Integrations > Hire a Consultant” category.
No question is too big. :winking_face:
Surprisingly, Airtable can do big things with Custom Apps. These examples are both from custom apps designed to create a seamless integration between MapBox and Airtable data. This video gives you the flavour of the Covid-19 map and you can even purchase a copy of the React code here.
