Formula problem?
1307 3
Ali_Aboutera
Any idea why this is giving me the same result? I assume this should be a negative number not zero right?![
https://photos.app.goo.gl/vyBy9Ij2WerlK2XF3
Day formula : DATETIME_FORMAT({Meeting Date}, ‘dddd’)
Days Remaining formula: DATETIME_DIFF({Meeting Date}, TODAY(), ‘days’)
3 Replies 3
What time of day did you test this - it may not have been a full day.
Make sure either all of your dates and formulas resulting in a date are set to use GMT or none of them are. Whenever I find some weirdness in date processing, that’s usually the culprit.
Anais_Laurent
Hello airtable community,
Do you have any idea why my formula equals “-0” ?
Capture d’écran 2022-04-13 145730
I would like to substract a paid amount to a due amount to let me know if i have paid the all amount or if i still have something to pay.
The formula works for the majority of the amounts but for some, it says “-0”
The 2 amounts are exactly the same, there is no other figure after the coma so I don’t understand
Thank you ! :slightly_smiling_face:
