Formula problems
972 3
sam_sam
Hi @all, I am trying to move everything that has the “finished” checkbox checked to another table.
Is this possible?
I am using integromat’s automation system.
here is what I’ve tried: image
18 - Pluto
18 - Pluto
Start by creating your formula in Airtable first, and make sure that your formula results in the number 1 for all of your records which are finished.
Then, you can copy and paste that formula into Integromat.
3 Replies 3
18 - Pluto
18 - Pluto
like this?
IF(Finished = TRUE()):
return 1
No, that is not a valid formula. Please post screenshots of your Airtable base, along with whatever formula you’re using.
