Hi, I’m using Commercial Real Estate Marketing Management. Is there a possibility of automatically generating flyers according to one template for all records (taking into account current data)?
Regards
Marcin
thx for answer, I know page designer but I don’t know how I can establish one pattern for all records and generate 20 flyers of different records at once
You will make one page based in your requirements. Then if you make Next Record it will get the same data from the next record and so on. You can print then all at one or choose which to print.
If you need help setting it up, feel free to contact me on mohamedswellam@hotmail.com
BR,
Mo
This topic was automatically closed 15 days after the last reply. New replies are no longer allowed.
