HELP! I accidentally erased 140 records
1093 5
Jeb_Colwell
I accidentally erased 140 records! Yikes. The undo function isn’t remedying it. Is there another way?
Jeb_Colwell
Oh sweet! Thanks @Kamille_Parks . You just saved me days upon days of work!
5 Replies 5
Jeb_Colwell
What happened is that in an attempt to delete a field, I pressed command+delete.
Check your snapshots to see if you can restore from a recent auto-save point
This will make a new base based on whatever snapshot you select, but from the new base you can export the data as a CSV and then import it back into your real one.
Jeb_Colwell
Additionally, you can click on the little trash icon right next to the snapshot icon. That will let you restore recently-deleted records, without needing to export/import.
Oh sweet!
Jeb, you marked your invocation as a solution, when you should mark Kamille’s reply instead :slightly_smiling_face:
