How to "hop" between tables
Topic Labels: Base design
587 1
Amy_Stults
I have 2 tables on one base that are linked together by one column of product names. When I click the product name on one table I would like to automatically jump to that row on the other table, but it opens up a popup box with details about the record. Is there a way to just hop over to the other table instead? Even in the popup box I don’t see anything to click to take me to the other table.
Hello @Amy_Stults!
There isn’t currently a way to navigate through a linked record to that record’s original table.
When you do click on a linked record in a table it will expand all of the information about that record. So from that expanded record view you will have access to read and update that record and any changes you make will be reflected in all the tables that record is associated with.
Could you provide more information on why you’d want to navigate from one table by clicking on a linked record?
