IF formula with differents dates
652 1
alexandre_Roy
Hello
I’m new in the Airtable community, and formula are definitely not my area of expertise,
I’m trying to make a formula that counts the days of difference between requested return date and the real return dates, however if dates are the same i want the cell to stay empty.
like :
Date return : 02/02/2020
real return : 02/13/2020
Delay : 11
i try with this formula without succes :
IF(IS_AFTER({Real return dates}, {Date return}), DATETIME_DIFF(
{Real return dates}},
{Date return},
‘days’
Sorry if this sounds dumb or simple, i’m very new to airtable and formula!
Thanks
alex
Hi @alexandre_Roy,
Welcome to Airtable Community ! :grinning_face_with_big_eyes:
I think the only problem you had is a formatting problem in your formula. (for example, there is an extra curly bracket after DATETIME_DIFF({Real return dates}}
This one works
IF(IS_AFTER({Real return dates}, {Date return}),DATETIME_DIFF({Real return dates},{Date return}, 'days'))
BR,
Mo
