Interface - number element resizing?
1339 4
augmented
10 - Mercury
10 - Mercury
Hi. Is there a way to change the size of this element? It has resizing handles but I can’t get them to do anything. Thanks.
18 - Pluto
18 - Pluto
I haven’t run into any issues with any resizing handles…well, sort of. If you’re trying to make the item smaller, you might have hit its minimum size. One of my main frustrations with many elements is that I’m not allowed to scale them as small as I want.
4 Replies 4
18 - Pluto
18 - Pluto
Yes, trying desperately to make them smaller.
John_Hite
+1 to needing certain elements smaller. Especially Number elements.
Also Left, Center, and Right justifications on Text element.
Cori_Kennedy
How was this solved?
