Is there a way to combine action to two or more Categories for Example:
Topic Labels: Sync
554 0
andres_Garduno
I am trying to use the Airtable software to organize files. I want to utilize the Status method in the category, along with location and automation. However, I don’t want to manually continue clicking just as I find another 300th file. Is there a way to automatically change the status of the categories without manually individually selecting it’s options?
0 Replies 0
