Need Airtable for Dummies I Think
Topic Labels: ImportingExporting
1804 6
Gaelen_Kash
I have a base in Airtable already set up that has several tables. One of the tables is my “Contacts” table. I have some additional contacts in some other places and I wanted to import them into this ‘Contacts’ table. So I imported a spreadsheet from a CSV file. The problem is that when I imported the spreadsheet it showed up in my base as ANOTHER table called ‘Imported Table’. Now, I can’t figure out how to add the contacts from my ‘Imported Table’ table into my contacts table. What I am missing here?? #AirtableLoser
6 Replies 6
18 - Pluto
18 - Pluto
Check out the CSV Import App.
Have Blocks been renamed Apps?
Thank you Scott World!
You’re welcome! Glad I could help! :slightly_smiling_face:
Yes, blocks were just renamed to apps last week.
If you don’t mind, could you please mark my comment above as the solution to your question? This will help other people who have a similar question in the future. :slightly_smiling_face:
I think I did, right? Don’t tell me I did this incorrectly too
Ha, yes! You did it perfectly! Thanks! :slightly_smiling_face:
