Page block features
Topic Labels: Extensions
710 1
Larry_Jackson
I am trying to decide to upgrade so I can use the page block. I am trying to take a contacts data base and create a promotional mailer card but have some questions. Can I take the data put it on a thumb drive and take it to a print shop and have the mass mailer printed with data base address’ on each individual promotional card. I know I can scroll through the data base on airtable but does it save it this way? I would be willing to work with a consultant if this is possible.
thanks
Larry
Welcome to the community, @Larry_Jackson! :grinning_face_with_big_eyes: I’m going to recategorize your post, as it doesn’t pertain to the Web clipper block.
To your question, you should be able to print from the Page Designer block to a PDF, which will create a single PDF document containing one mailer for each record, then take that PDF to your printer.
