Password Problem
1650 1
Kelly_Shank
I’m trying to add the Airtable app to my phone but can’t because it says I have the wrong password so I tried to change the password on my laptop, but because I don’t have the current password I can’t change it on my account.
Am I totally out of luck or is there a way to change it without knowing the current one?
Pete
7 - App Architect
7 - App Architect
Sorry for the trouble here – as long as you have access to the email address associated with your Airtable account, you should be able to reset the password to your account from Airtable.com/forgot.
Does this help?
