Sharing base with view overview default collapsed
Topic Labels: Views
689 0
Carolin_Franken
Dear Airtable community,
I want to share a base but the view overview on the left hand side collapsed so it is not noticeable. Alternatively I could also just share a dedicated few but I also want the apps for the base to be included. Can I add them to a view?
Sharing the base with the view overview collapsed by default would be better since the link has already been created and shared. Thank you!!
0 Replies 0
