SORT- for Link and Lookup
Topic Labels: Views
551 0
Jeff_Bouldin
  1. For Link Table, I have been able to do a “batch” sort, however it only sorts for the first field. Is there anyway to sort this Link Table by multiple fields?
  2. For a Lookup Table, how do you sort this information whereas when I expand the record the Lookup records are sorted?
Thank you
0 Replies 0
