Using cell data in Automation Message
Topic Labels: Automations
555 1
Allison_Ruork
Is there a way to add cells from an airtable to a message sent via automation? So if the conditions for the automation trigger are met could the message include information from variables/columns for the row triggering the automation?
Welcome to the community, @Allison_Ruork!
Yes, that’s what automations are designed to do.
You can learn more about automations here:
Also, your timing is fantastic, because there is an automation webinar coming up tomorrow! Here’s the link to sign up: https://airtable.com/shrJmMweUV9AJpGxd
