Mar 29, 2022 12:13 PM
Hello, I’m new to Airtable, (trying to help a friend build an efficient solution) and I’m looking for some advice. We have a form with a rather large multi-select field. Users must enter their name, date and select any number of options from the multiselect field.
The information comes into the table in the way you would expect:
But in order for it to work with my friend’s processes (and existing tables) they need a way to break the record up (ideally on form submission) into multiple records:
I found a way to do it with automations. I created an automation for each Option to check to see if that option has been selected, and then create a new record. Unfortunately, this is time consuming and will not scale well.
Can you recommend how to build an automation script (or other solution) that can automatically parse the multi-select field into multiple records, one for each selection?
Thank you,
Solved! Go to Solution.
Mar 29, 2022 03:44 PM
You say that you are open to a scripting solution. What is your experience with writing scripts? While this is would be a straightforward script to write, it might be too much for a someone new to writing scripts, unless you were highly motivate to learn scripting.
If you are not comfortable writing a script (or cannot hire someone to write a script), you could use a system of text fields, formula fields, and automations to create the records.
Mar 29, 2022 10:37 PM
Thank you for your solution, It’s been a while since I’ve written much code (and never for airtable), so I really appreciate your alternative solution. I was able to implement your solution fairly quickly and it seems to be working really well.
I had a little trouble with step 2. I set up an automation to trigger ‘when record updated’ while watching field 2a, but it would only run one time. Instead, I set up an automation to trigger when ‘record matches conditions’ where the condition is ‘2a is not empty’. Now it runs through each step until there is no value in 2a.
For anyone else looking to do this, here’s how I implemented Kuovonne’s solution:
Initial Form Submission & Formula Cells
Automation #1
Field 2a:
IF( FIND(",", Stringify),
LEFT(Stringify,
FIND(",", Stringify)-1
{Stringify}
Result: Populates Field 2a with the ‘first’ choice in Stringify. -1 removes the comma.
Note: Kuovonne, Thank you for this formula too. I found it in one of your old solutions elsewhere in the community.
Field 2b:
IF(FIND(",", Stringify),
RIGHT(Stringify,(LEN(Stringify)-FIND(",", Stringify)-1)
Result: Populates Field 2b with the remaining options. -1 removes the comma from the text. If there are no strings left (indicated by no commas), it sets Field 2b to a null value ("").
Automation #2
Here are the results: (Checked records were automatically created)
I didn’t end up implementing a scripting automation to delete the original record. My friend wants to hold onto them as ‘receipts’ for the original form submissions, so I will be moving the auto-generated results to a different table.
Thanks again!!
Mar 30, 2022 10:57 AM
Glad you got a working solution! You are welcome for the earlier formula for identifying the first element in the list. Airtable has since released the REG_EX functions which make this even easier than the formula you found, but use what works!
Your system has a few slight differences from what I envisioned, mostly relating to the triggering record and which fields are copied in which records. I was picturing having the original record be the triggering record in all cases, but your method where each newly created record triggers the creation of the next record works too.
