The Airtable Community will undergo scheduled maintenance on September 17 from 10:00 PM PST to 11:15 PM PST. During this period, you may experience temporary disruptions. We apologize for any inconvenience and appreciate your understanding.
So I am looking to utilise this, the base I am looking for is I enter a property address and it will create a task list of items such as photography, entering data into our system, safety checks all these to be either as Not started, in progress or completed. Of which the role for certain tasks will never change simply I would like for 1 name/property to be entered and it just creates all the tasks automatically.
Hi, use automation. I would recommend to add checkbox or single-select field after property name and use it as trigger, otherwise, if you use text field, ('When {Property Name} updated' or 'When {Property Name} is not empty'), automation will run immediately after you enter first letter in the field. Single-select is a good option when you have several different sets of task lists.
