Jun 17, 2022 01:42 AM
Hello everyone, :wave:
I’m having some odd behaviour I can’t figure out.
I have a formula rolling up invoices linked to a case.
IF(Statut = "Clos et facturé",MAX(values),"Dossier ouvert")
It does not work.
The cell shows up empty when it should show the last invoice date.
But if I try:
MAX(values)
It works.
And if I try:
IF(Statut = "Clos et facturé","test","Dossier ouvert")
It works too.
I’m puzzled as to why my first formula does not work.
Thank you for your help,
Joachim
Jun 17, 2022 03:41 PM
You’re always going to run into trouble when mixing numbers or dates with string values.
If you want a field to show both dates and strings, you need to convert your dates into strings using DATETIME_FORMAT(). This also may require you to use both the Rollup field and a Formula field if doing everything within the Rollup still doesn’t work.
